cummins2014
Feb 13, 2022Explorer
humblerb wrote:cummins2014 wrote:humblerb wrote:
Update:
Well, since I am retired and have lots of time on my hands - I found a coarse round file in my tool box. Used a little (or a lot) of elbow grease and manually reamed slightly. Repeated a few times. I was a little surprised at the ability of the round file, but it worked rather well.
Pins now go in with less hassle. The last one takes a little manipulation for now.
I'd rather have a little tight than a little loose.
As I install and remove the hitch in the future, I may decide to ream a little more.
Curious did you ream the adapter or the tabs, I believe I would ream the adapter , less metal thickness to deal with ,and no compromising those tabs , the adapter frame holes has plenty of steel there that it wouldn't weaken it at all . I know the tabs are pretty thick, but they are also not that wide .
I reamed the the tabs. The steel there is much thicker than the adapter. I felt there was less chance of compromising the steel with the thicker tabs than with the thinner adapter.
Yes, the tabs are much thicker ,but that frame has more mass , and you are going side to side , not up ,and down , you got what three feet of tubing there , there is no compromise if those hole were 1/8" longer . Thats my thinking anyway, and would have been much easier to open up that 1/8" on that thinner tubing . But its done now , sounds like it all worked out .
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
