Cummins12V98 wrote:
jaycocamprs wrote:
Cummins12V98 wrote:
Honestly don't know the problem but most all beds with damage I have seen have this type of handle on the hitch.
I said without issue, but over the years I did have a few times that it failed a pull test or visual inspection. Once the disk slipped and the teeth bent down keeping the pin from fully seating. Other times just try again. But we never had a drop.
Once we made the choice to get the factory mounting pucks in the new truck. Getting the B&W was a done deal. And a choice I am quite glad we made.
Do you do a pull test with the B&W now that you have used it a few times?
I have not done so for at least 10 years.
Look at Jaws closed around kingpin handle locked not going to fall.
Let me just say...
The AUH is by far the easiest fifth wheel hitch in terms of verifying solid connection.
