- cummins2014Explorer
Cummins12V98 wrote:
Just concerned for your safety. ;)
And I do appreciate your concern , and save travels to you . - Cummins12V98Explorer IIIJust concerned for your safety. ;)
Cummins12V98 wrote:
cummins2014 wrote:
fj12ryder wrote:
Don't the bolts on the hitch itself need to be checked periodically, as you would any retaining bolt? And also the bolts on the king pin block, don't they need to be checked for tightness? This would come under the heading of maintenance, at lest in my mind.
Here again , no maintenance, no checking tightness on mine . Nothing , there are no bolts to check , the lugs on the adapter are pinned , as well as the hitch . The ones that have the steel Andersen know this . As said you have to have one to know what goes on .
As far as the adapter on the kingpin , never checked it . Again if you had one you’d know why . I’ve had it off several times , and seen why there is no need , if you had one and wanted to check it that’s great , I have no problem with that if you think you need too . Some grease their bearings every year , I don’t . As with all things I do look at it periodically for anything obviously wrong with it .
NEVER checking something you hav bolted on that carries so much is IMHO dangerous.
Come now , been around machinery hitches etc my entire adult life . I know how that adapter is bolted ,,and what to check, and I don’t let anything slide , nor the hitch , don’t you fret that I’m doing something dangerous :) - Cummins12V98Explorer III"And to tell you the truth, I'll never own an Andersen."
Things are not always as GOLDEN as they may seem. - Cummins12V98Explorer III
NEVER checking something you hav bolted on that carries so much is IMHO dangerous. - Cummins12V98Explorer III
cummins2014 wrote:
Flashman wrote:
TXiceman wrote:
Flashman wrote:
TXiceman wrote:
Look in the owners manual for the hitch. All hitches do require periodic cleaning and maintenance.
Ken
Wrong - not my Andersen.
You mean it never requires any cleaning or checking for tightness and mounting....Good Luck.
Ken
Yep that's what I mean - if you have not owned one you would not understand.
Could not of said it better , many have no understanding of the Andersen ,but continue with opinions of it. I wouldn't tow with anything else after having one now for a few years, and I have towed with as good a conventional hitch as there is ,with no issues that I keep reading about the most popular conventional hitch , the adjustments ,bolt replacements etc . I will stick with the Andersen ,no maintenance, replacing any parts etc etc .
You don't have the bed deflecting/folding Ultimate now do you?
I would not have a problem using YOUR hitch for a lighter RV, say 14k and under. - TXicemanExplorer II
Flashman wrote:
TXiceman wrote:
Flashman wrote:
Ken
Ken
Nope but I have had to assist people in the park with the Andersen get then to release and unhook. Wound up putting blocks under the front jacks and lifting the ball and shank out of the hitch....that is a high lift to clear the hitch. The other lifted the whole hitch out of the bed and then literally beat the thing to make it release the ball. In both cases, the release cable was corroded.....due to NO MAINTENANCE.
Ken - cummins2014Explorer
As far as the adapter on the kingpin , never checked it . Again if you had one you’d know why . I’ve had it off several times , and seen why there is no need , if you had one and wanted to check it that’s great , I have no problem with that if you think you need too . Some grease their bearings every year , I don’t . As with all things I do look at it periodically for anything obviously wrong with it . - fj12ryderExplorer IIIDon't the bolts on the hitch itself need to be checked periodically, as you would any retaining bolt? And also the bolts on the king pin block, don't they need to be checked for tightness? This would come under the heading of maintenance, at lest in my mind.
Flashman wrote:
TXiceman wrote:
Flashman wrote:
Ken
Ken
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
