- FlashmanExplorer II
TXiceman wrote:
Flashman wrote:
TXiceman wrote:
Look in the owners manual for the hitch. All hitches do require periodic cleaning and maintenance.
Ken
Wrong - not my Andersen.
You mean it never requires any cleaning or checking for tightness and mounting....Good Luck.
Ken
Yep that's what I mean - if you have not owned one you would not understand. - cummins2014Explorer
TXiceman wrote:
Flashman wrote:
Ken
Ken
At a glance is all , no tightness to check . Just to make sure no one has messed with any pins . - TXicemanExplorer II
Flashman wrote:
Ken
Ken - rhagfoExplorer III
przao wrote:
On an aside, he uses a portable electric grease gun to generously lube the hitch plate every time he hitches his semis, and told me to do the same because he noticed what he called high pressure wear on my hitch head even though I was using a lube plate.
What a mess!!! This is why I use a lube plate, no way would I use grease, except the pin contact points with the hitch jaws. - CampinfanExplorer IIII wish the original posters would update us on how things went. I am not trying to be mean but many never update us. It would benefit all of us to know what worked, again not just in this post, but in others.
Ken
Wrong - not my Andersen. - ACZLExplorer
Cummins12V98 wrote:
ACZL wrote:
Cummins12V98 wrote:
You will have a mess if you grease the head.
Exactly. All the grease will get pushed off and either end up on edges of the hitch, on the floor of truck or on the rest of the hitch in front part of it.. Plus not to mention that the king pin/hitch on RV will be coated w/ grease and be a "B" if ya run into it.
I assume there is some sort ofd dry lube that can be sprayed on the hitch head?
Dunno. Just going by how the grease ends up on our semis. - Cummins12V98Explorer III
I assume there is some sort ofd dry lube that can be sprayed on the hitch head? - ACZLExplorer
Exactly. All the grease will get pushed off and either end up on edges of the hitch, on the floor of truck or on the rest of the hitch in front part of it.. Plus not to mention that the king pin/hitch on RV will be coated w/ grease and be a "B" if ya run into it. - Cummins12V98Explorer IIIYou will have a mess if you grease the head.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
