- I had one on my previous 5th wheel and it caused me to have problems while trying to hitch up.. The straight edge on the front of the trailer (just in front of the king pin) should contact the truck hitch and pivot it level for proper alignment. It "cams" the pivoting hitch to proper alignment. With the round teflon pad on there, it would sometimes not allow the Reese to pivot level and thus cause problems. I would sometimes get a "high hitch situation" where the king pin would end up on top of the jaws. I took it off and NEVER had any further issues. Don't use one on my new 5th wheel either.
- danrclemExplorerOrder two and keep one as a spare. They're cheap on da bay.
- TenOCNomad
Dave H M wrote:
My hitch either hangs on the king pin when in storage
My FW will be stored outside. Is it necessary or only a good idea to cover the hitch when hanging from the king pin. Will the hitch rust when exposed the the weather for a number of months. Can I simply wrap it in a plastic sheet or do I need something that will let air in but not rain. That is some type of "breathable" material. I do not think I can use a store bought hitch cover when the hitch is attached to the king pin. - Dave_H_MExplorer III got a good one for the OP. He should now ask if he needs a diesel dually. :B
Heck yeah, it is a good idea if you got the clearance!
My hitch either hangs on the king pin when in storage or resides in the truck when in use. Thus the logic of why i will never have the slippery hitch imprint on my beer belly. - ckwizard777Explorer
Helmsey wrote:
C.B. wrote:
Just a word of caution. If you use a Pullrite hitch DO NOTuse a lube plate.
Tolerances are to tight.
C.B.
I don't have any issues on mine. I have the 20k ISR hitch and use the same lube plate I've been using for a couple years now.
You are correct it is tight but there is plenty of room.
I have used one on my Super Fifth for the last 10 years with no issue.
You just have to come in slightly high when hitching up so that you are lifting the trailer as you hitch up. Also eliminates high hitching. jffnkrn wrote:
We use a Lube plate. upgraded for tt to fw 2 years ago. never had an issue. others may claim they tear theirs up when hitching and don't use them any longer.others may claim they tear theirs up when hitching and don't use them any longer. Just make sure you have a bit of clearance when hooking up and you will be happy. And - like earlier said, doesn't take away from needed lubrication on the inside of the hitch, and leaves no mess to deal with. We also added a cover to our hitch when not in use. Keeps dust, dirt and water out of inside. Good Luck & Be Safe ! ! !
mine gets torn up if i try to hitch with the pin box to low.- Sonora108ExplorerI've been using a Reese 83002 Lube Plate which is 3/16" and it works fine with my B&W Companion, have no problems hitching up.
Yes - definitely do use a Lube Plate unless you like grease on your clothes.
Bill - Cummins12V98Explorer IIIIf you buy a B&W hitch I advise getting the Hensley 1/8" thick lube plate.
- HelmseyExplorer
C.B.
I don't have any issues on mine. I have the 20k ISR hitch and use the same lube plate I've been using for a couple years now. - C_B_Explorer IIJust a word of caution. If you use a Pullrite hitch DO NOTuse a lube plate.
C.B.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
