MFL
Jul 27, 2022Nomad II
IMO, towing with the diesel, the weight will not make much difference. The height diff will make about the same diff as the weight.
Also if looking at GVWR sticker to compare, that may have more to do with axle/spring size, such as comparing 4,400 rated axles to 5,200/6000 axles. The beefier axles/springs allowing a higher wt rating, rather than actual scaled wt of the various trailers.
Jerry
Jerry
About Fifth Wheel Group
