TXiceman wrote:
A 1/2 ton truck is severely limited as for towing by the rear axle GAWR and the payload capacity. The payload capacity included the trailer pin weight, hitch weight, passenger and cargo. A typical 5er will have a loaded pin weight of about 20% of the trailer GVWR. So if your trailer has a GVWR of 8000#, the loaded pin weight will be about 1600#. A short bed truck should have a slider hitch, so add another 200# to the bed. Add 2 kids and a wife and any cargo in the truck and you have another 300# or more. Your load on the truck is 1600 + 200 + 300 or 2100#. Is your truck payload or cargo capacity over 2100#. YES!
Also, most 1/2 ton trucks on the dealers lots have P series tires, not LT series tires. The P series have softer side walls and will squirm more under load.
Ken
And it also has LT tires.Actually, the badge on the side isn't the determining factor; the ratings on the door and elsewhere are. I have more payload then some F250's.
