SonnieP wrote:
JIMNLIN wrote:
Your 1500 Ram can tow a 5th wheel trailer but it would be a small one. Those that say a 1/2 ton truck can't/shouldn't tow a 5th wheel trailer. They are not all the same size. GVWR can go up to 8600 gvwr but more importantly RAWR up to 6000 lbs depending on truck brands/year models.
You have the truck so like all truckers you need front and rear axle weights, after loading hitch/folks/junk, to know how much capacity you have to work with which I would bet is going to be close to that 1612 lb payload numbers.
I would stay under 8000 lbs max "gross" TT weight for a more relaxing operation on long day trips. The 5.7 Hemi at 395 hp/410 torque coupled with the 3.90 rear axle ratio sure won't have any issues pulling a 8k trailer.
You mention a 5.8 etorque engine. Is that a typo ??
Thanks for the info... and yes... it's a 5.8L Hemi with the eTorque.
Still a typo. There is no 5.8l hemi. It’s a 5.7l in the Ram 1500.
