djm560's avatar
djm560
Fifth wheel slide issue
I have a 2012 coachmen 320 rlts and noticed wires hanging down under
The slide once I pulled it in . I put the slide out to get a better look and there is a flat plastic piece about 4-5" wide that runs perpendicular with the slide and is connected to the slide and trailer . It has wires that run backs and forth through it.it looks like it protects the wires when the slide moves . It is broke at the frame . Does anyone know what this is called so I can find a replacement. I can replace it myself if I could find one on the Internet . Looks like a poor design and it may break again. Anyone have any other ideas how to fix?
  • The plastic thing is from Lippert. They don't last. I used a common door hinge bolted to the plastic and the frame which lasted 3 years til I sold the trailer.
  • Sounds like the zip ties are the best way to go . I can always count on this forum for answers.
  • BB_TX wrote:
    Common problem. Some have attached metal hinges to the broken end of the plastic and attached the other side to the metal frame.
    The way mine broke I drilled 3 holes in the broken ends and used 3 large wire (zip) ties to hold the broken ends together a couple years ago. When (if) they break I will just use more ties.
    X3
  • Common problem. Some have attached metal hinges to the broken end of the plastic and attached the other side to the metal frame.
