I guarantee that you will never find a FL with a larger wrap around booth with seating for 8. Even in a 40' 5th. Front living models are usually the higher end units. If you want seating for 8 in a wrap around booth dinette then you need to give up the FL floor plan. The issue is the sofas are usually running front to back in the two front opposing slides and an 8 person booth will be 8' long or maybe longer. Adding up the length of the sofa and the booth and that's 16'+. Large wrap around dinettes will always run front to back in a slideout unless they're in the rear of the 5th.
