laknox wrote:
Put a 2' cheater on most any 1/2" ratchet, and you're likely to break the wrench. Translate that torque multiplication onto a GN adapter and the forces acting on the FW frame. You're, in effect, putting an 18-24" "cheater" on the king pin.
Lyle
Yes, from an engineering standpoint there is the possibility to put more stress on the hitch with an adaptor but not an 18-24" "cheater" bar. Here is mine with the long pin box. If I remember correctly in the last 5years plus, there has only been one or max two frames broken with an adaptor but more that have never been converted. Pivoting a 5th wheel beyond the couple degrees most new hitches are made to pivot to the sides so that the hitch takes the stress from the truck also far exceeds the extra stress the extra 6 inches or so will ever put on the frame.
The stress from the goose box would be identical to any other hitch with the same dimensions.
Lippert knows this yet they still only allow the goose box because it puts $$ in their coffers.
