Wish my Goosebox did not require re-airing the airbag after almost every tow as it has a 50PSI pressure relief valve that apparently squirted out the 40-45 PSI I put in the bag, and was very slow to refill for such a small airbag. Also, my instructions indicated the coupler should be greased before every tow. And after my frame broke and "bent" the Goosebox after only having it for 8 months, it was not a warranty failure and despite claiming they did not know of any failures, Reese refused to provide a new Goosebox. Cannot recommend it.
