cummins2014
Oct 29, 2020Explorer
edatlanta wrote:JAC1982 wrote:
The reason we went with a Montana High Country was because it was the only one in our price point that came with a gen prep option for the Onan. Grand Design Reflection, Jayco Eagle etc. did not, not even as an option. I think all the "higher end" ones do though... Montana, Solitude, Redwood. But sub-60k, Montana HC was it from what I could find. We had the generator installed ourselves after purchase from an authorized Cummins dealer/installer, it was a little cheaper than having the dealer do it.
We came from a toyhauler with the on-board gas Onan as well. This new one is propane, and honestly I liked the gas one better. It seemed more efficient. We're actually buying a 4500 portable generator for use when it's colder, because the onboard uses up a lot of propane.
I have a 5500 Onan that was factory installed and it is gas. I like it a lot. Right now I'm using it to provide power since the entire town is dark after the storm passage a couple of hours ago. I find it a lot easier to fill a gas tank than a propane tank and the gas tank lasts a lot longer. I use non-ethanol gas in my rig and keep stabilizer in the fuel year round. I also run the generator 1 hour under load the first of every month. So far it hasn't failed me. Today's run will take the place of the normal run on the first of the month obviously. 2 hrs running as of right now and I would expect 6-8 hrs more to go. Lots of lines and trees down.
My previous fifth wheel I ordered the Onan 5500 LP , IMO its great for emergency use like what you are doing, but running them long term is pretty impractical . We used ours a few times when the power has went off in a small RV park we stay at every summer in Montana, and a few other times during that 12 years .
We went to a Montana rally early on when we first bought our 2008 Montana, and it was called the circling of the Montana's . It was dry camping outside Quartzite ,Az. in January . We ran that Onan quite a bit, and I spend a few trips going to Quartzite for propane :) We very seldom go anywhere we need to run the air conditioner. Our annual trip in the summer in Montana, the weather is pretty mild. Now days with our present fifth wheel, it does not have a onboard generator, all we need if we use the fifth wheel for hunting or whatever with no power, is our Honda 2000, it takes care of any needs we have . I will probably never buy another fifth wheel, and install a onboard generator.
Just got back from a hunting trip, and we ran that Honda off ,and on for 5 days , my wife had it running probably a good 10-11 hours per day. I run it with a 6 gallon extended run tank attached to it , in those five days I went thru about 9 gallons of fuel. I added to the extended run tank the last two mornings before I left camp to make sure it did not run out before I got back to camp.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
