rodneyhughwilli's avatar
Mar 04, 2015
Fifth Wheels with left side or rear door
G'day Mates, I'm Rod Williams from Brisbane, Australia. I was wondering if anyone knows any of the RV Manufacturers or any RV Makes or models that are built with either left side or rear entry doors?
Also any manufacturers that build fifth wheels with 240Volt electrical systems?
Many Thanks and Good Luck, Rod.
  • Our new cougar 301SAB has a left side entry door, although it leads to the 1/2 bath, but still allows entry into the rest of the coach
  • Keystone Montana has the 3850FL which has the right side and left side doors. Tim
  • I assume a fellow Aussie will show up shortly to advise you.
    G'Day matey.
    bumpy
  • Wildcat has some with a rear entry as well as the traditional US curb side door. Other Forest River models do as well. They are the huge bunk house models with a rear 1/2 bath.
  • Old model years there were some also, Fleetwood made some with rear doors. Even seen a couple with doors on either side.
    If you want to spend money, New Horizons does only custom work and would build exactly what you want, but I know it will not be cheap.
    Sans the air-conditioning and power converter (maybe water heater) most things in the rig run off 12VDC anyway.
  • http://www.americanarv.com/sequoyah.asp For one manufacturer and they might even make a 240V
    Cedar Creek has one with a left side door
