pexford's avatar
pexford
Fifth Whl vs Trvl Tralr
We have a 2011 24' Passport that now has about 40k miles...only 6 more States left to camp in. But now looking @ a new rig. Heavy travel days are over. Something less than 30'? Maybe a Fifth Whl but don't know. Anyone out there that has pulled both? What's downside? Thinking of the pain of the hitch 'cause I want to keep the bed of the truck clear when not towing. What's upside? Mostly interested how Fiver handles, stability, backup, hitch-up, unhitch, turn radius, etc. Will pick brand & model ourselves, not looking for endorsements.
  • Thanks for the reply Jerry. Nice to have this forum available. Always get quick responses and good info.
  • I'd start without anything and stay that way if you like it. The two reasons for bags or timbrens is to fix sag or to improve the loaded ride. The former is objective and unlikely to be an issue on a new 3500, but the ladder is subjective and depends on personal preference.
    Congress on the truck - huge upgrade over your light duty Ram.
  • Dayle1 wrote:
    I find that driver fatigue is less with a fiver. It isn't just due to a more stable rig with less sway, although that is a big reason. While WD and sway control do their job, I still feel the TTs influence on the tow vehicle at every bump/dip etc and it wears on the driver over hundreds of miles. OTOH if a fiver setup has severe chucking, that also increases driver fatigue, but most of my fivers have not had this issue.
    We have had both TT and now 5th Wheel. When we first bought the 5er, I almost reneged on the deal due to the "Chucking" with this 43' Toyhauler. It took an "Airborne" kingpin and Armstrong Airbags on the truck (F-450) to get the chucking under control. I had never heard of chucking until I bought a 5th wheel. As others have stated, pulling a 5er is easier with the exception of the "Cheating" while making turns and slow reacting while backing.
  • Honestly, I've towed both and a fifth wheel any day. That are much safer with distibuted weight, they have more space and are maneuvered easier. The downside is they are huge and take up bed space, but yo can put bikes and stuff under the hitch, they are heavier in some cases. A travel trailer is putting all the weight on the trailer and a bit on the truck-not as safe. You will need a truck for pulling anyways, so I would say your not losing much and go ahead with a 5er
  • Unless you are getting a really big, heavy FW, you won't need air bags. Also, FWs don't need weight distribution since the hitch generally rides over, or close to, the rear axle.Is your Ram a dual or single rear wheel, that does change the load capabilities and somewhat the towing performance.
  • I fulltimed in a fiver for a number of years, but had to give it up due to a sudden health crisis. The fiver towed beautifully, and I used a short bed 1 ton diesel, single rear wheels without a problem. There is still some concern with a short bed truck when making a very sharp turning maneuver but there are special hitches that address that possibility. I got by with a standard hitch by just being careful when making tight turns.
    A big plus factor with a fiver, as others mentioned, is extra room, not only inside, but for storage as well.
