C.B. wrote:
Does this look like yours
If so turning valve to gravity should fill tank.
Suggest you open fresh water drain to see if there is water in the tank already
hope this helps.
C.B.
This is exactly like ours. It did not fill the fresh water tank though when we turned to gravity. It ran straight to the ground at the fresh drain. It was not overflowing either. I thought at first maybe the tank was full and indicator was not working (it shows empty) but when turn pump on, there is no water. Even tried to allow to prime pump. Nothing. Was afraid would burn pump up so turned off. When we get where we are going, I’m going to check drain and see if valve or cap (not sure what is there) is open. Perhaps it was never closed when draining a couple of years ago??? Not really sure. Thanks for your reply. This helps to at least know I wasn’t crazy and was at least doing it correctly.
