NC_Hauler
May 07, 2015Explorer
ACZL wrote:
A 3/4 ton overweight??? Never heard of such a thing! Want to see overweight, how many 1/2 tons are going down the road with their headlights shinning into the trees? 1/2 tons towing very large 5ers?! Yes OP is overweight some. Ratings by MFR's are to cover their butts. In this case, if Ford says the max weight of a trailer is 12,000--I don't know exactly, but let's use it for argument sake), you can rest assured Ford tested it with a 24,000 trailer knowing full well folks will hook a heavier trailer onto it above 12,000.
Does it make it legal, no. Overweight is overweight. BUT as long as the owner is fully aware of things and keeps a "safety" cushion around him, everything should be alright. Note, should. In the unlikely event he's involved in a crash (depending on severity), he could be in for a good lawsuit. There are plenty of overweight 1/2, 3/4 and 1 ton trucks running up/down the hiways.
I know of 2 folks that have 3/4 D-maxs and are waaaaaay over the limit for them. Yet, not a scratch on them. Plenty of aftermarket items to beef up a susp, engine or what have you, but seeing the OP is under 2,000 overweight, I wouldn't make a big fuss about it like some have on this thread. Biggest thing is knowing what you have and how best to handle it.
Really want to blow this thread up? How does it make folks feel about a 3500/450 trucks maxing out at 33,000-35,000 and not used to towing that much weight WITHOUT a CDL??? Don't know about you all, but that scares the bejesus out of me while someone who drives for a living has to have a CDL for these weights, BUT IS use to them. Yet noone is complaining about the ave "Joe" buying a 45' diesel pusher w/ tag axle towing a 20'-30' enclosed trailer behind them who just yesterday was driving his/her Impala around town.
Very good observations...especially with the 45' diesel pusher and towing a trailer behind it big enough to park a 1/2 ton pick-up in it:)....
I'm "sorta' like Rick, I work with GVWR numbers, KNOWING I'm well under that right now and even more under my trucks RAWR...So I can still purchase a much heavier 5er and would go over my trucks GVWR, (done it before), BUT still be WELL under my trucks RAWR...Ram rates it at 9750#,( E rated 17" OEM tires aired to 65psi).. AAM rates this rear axle at 11,800# (300mm), so one could get a higher weight rated tire that could handle more weight than OEM tires, and STILL be under the AAM ratings of 11,800# by quite a lot...if one wants to push it that far....I just don't think it's wise to go over the Axle MANUFACTURERS weight ratings on THEIR axles...THEN, I think you're asking for trouble....
As far as 3500 maxing out at 33,000-35,000# , (if talking 3500 Dually), my truck with 4:10 has a GCWR of 37,600#....that being the case, I feel I could load my truck to 33,000-35,000# and still be fine...( I also figure the GCWR numbers are conservative ALSO, BUT, 33,000 to 35000# GROSS, DOESN'T exceed my trucks GCWR numbers:))...AND, I won't need a CDL license...but I've seen 18 wheel CDL licensed drivers that shouldn't be driving those big rigs either.
About Fifth Wheel Group
