goducks10
May 07, 2015Explorer
SkiSmuggs wrote:Allworth wrote:
You really shouldn't post here if all you want is for everybody to agree with allowing something wrong to continue.
Over weight is over weight.
GVWR is a limit, not a suggestion. Nothing you can do to springs, air bags, or any other gimics you want to stick under there will change the fact that you are over weight.
You need more truck.
The end.
Ford takes the F250, adds an overload spring and a 4" block, calls it an F350 and rates it at 11,500 lbs. I don't see the difference.
I am NOT saying you can make an F150 into an F350, but you can just about make an F150 into an F150 HD Payload with springs and shocks. The rear axle is the only thing left.
I'm not sure about the 2015 F150 but I don know that the HD F150 prior to 2015 actually has a thicker frame. Also it has a 4800 RAWR and 7 lug rims. I don't think just adding bags or such to a max tow version would equal an HD.
About Fifth Wheel Group
