lenr
Mar 12, 2020Explorer III
Slight delay in disk brake actuation seems to be extremely common and accepted by many as just the way it works. I also believe that the turn on voltage of the actuator may also affect the sensation of delay. In my case upon light braking the engine brake works well enough that I don't have to push the pedal very hard which in turn doesn't send enough voltage back to turn on the actuator. Then, if the rig is not slowing enough and I push harder, I experience a slight delay as the actuator pump finally turns on and builds pressure. The Titan actuator I am using now has a distinctly lower turn on voltage than the Dexter that I started with. Had a thread on this back on 7/16/19: https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29930221/srt/pa/pging/1/page/1 Eventually, I plan on installing a Prodigy to see if I can set it to turn on as soon as I touch the brake petal, keeping it on through the entire braking process.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
