jimmyfred
Jun 02, 2014Explorer
.............I grew up in Midland,tx........there are boom and bust cycles associated with the oil Bizz ! This 'Boom' is going to last far longer and be far stronger than the previous cycles ! Drilling will slow down eventually , But , maintaining production levels means lots of jobs will continue 15 or 20 years into the future .
.............I would encourage you to invest in a Used , Up scale 5'ver for long term use and comfort ! Travel Supreme(my 5'ver) are extremely well made trailers . Teton is another top scale 5'ver that is made for FULL Time living .
.............There are significant differences in quality between the midlevel trailers and the 'TOP' brand names . Mobil Suite , Hitchhiker , Travel Supreme , Teton , and several others are available as used units that facilitate full timing living in very hot and very COLD climates .
..............The steel in the frame in the top trailers is much stronger and heavier than less expensive units . Any unit you purchase should have the under belly......FULLY.....covered , this prevents mice and any other critters from gaining access to the interior of your home . Should also have 2-15,000 Btu air units and come with 50 amp service as well . Just do your research before spending your money and you'll be able to make a wise decision . , Good luck , jf
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
