AZ_T_T
May 19, 2013Explorer
bobsallyh wrote:
Before you "repacked" did you pull the hub off the spindle and actually check the bearings and look to see how much grease was already in the hub?
Nope that is the joy of the Dexter Easy Lube. The spindle is hollow, so the grease goes to the inside bearing and the pushes the old grease forward. You pump the grease in until you only have new grease coming out.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
