pcm1959
May 19, 2013Explorer II
Good luck with that. I hope your grease and bearings were warm so it flowed easily. I hope that you turned each wheel while pumping the grease into the hub. Turning the wheel while pumping the grease is right from the Dexter manual. In an ideal situation, they work as designed. However, most people don't use them ideally. The rusult is pushing out the rear seal and grease contaminating the brake shoes and drums resulting in virutally no brakes. I hand pack only. Hoefully you did not blow the seal. Phillip
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
