broark01
May 19, 2013Explorer II
Just pulled all 4 of our 2008 ez-lube hubs on Cameo and replaced everything from the brake backing plate out including shoes, magnets, all bearings, races and seals. Only 1 showed any sign of grease being forced past the seal and no obvious shoe/drum contamination. The biggest shock was that the spring shackles had completely CRUSHED some of the brake wires against the frame so badly bare wire was exposed and ripped. Be sure to check all brake wires. We bought the 5th wheel used and you never know what the guy before you did and how often he did it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
