MFL
May 20, 2013Nomad II
cwit wrote:
How many pumps on the grease gun does it take to fill the inside cavity and not push out the axel seal? I think this is an unsafe system and should never be used. I think over weight is safer than no brakes and I'm not into overloading either.
The Dexter EZ lube has been around a long time, and is a good system, if used properly. The problem is when owners never pull their hubs, to check the brakes and bearings.
If your seals are good, not reused, damaged etc., the grease should pump out the front around the zerk, if you over grease.
It would take quite a few pumps to fill the system, if there was no grease in there to start with.
Happy travels,
Jerry
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
