mrad's avatar
mrad
Explorer II
Aug 28, 2020
First timer with 5th wheel hitch question
n July I purchased Chevrolet 3500 Duramax. I had previously had a 5th wheel hitch in it. The prior owner told me he had a Reese 16,000 lb non slider hitch that was in it. He was selling that hitch separately and offered it to me. I was thinking I wanted an auto slide and did not purchase the Reese. A local RV repair shop knew I was looking for a 5th wheel hitch and contacted me and told me they had a consignment pullrite auto slide 16,000lb auto slide that the owner wanted $700 for and they would install it for $500. When I asked why the price would be $500 for a truck that already had a 5th wheel hitch in it, they said they install them differently and drill holes into the frame as they felt that was a better, safer method. I know nothing about 5th wheel hitches as I am coming from a TT. Does this sound reasonable that the frame should be drilled into to support the pullrite hitch?
  • you don't need a slider if its a long bed 3500. I have the reese rails with a patriot hitch. I also have a 40 gallon aux fuel tank and my 7000 honda in the back and still have lots of room.
  • mrad wrote:
    ACZL wrote:
    There are holes in frame already and aftermarket rails made by B&W, Reese will bolt right onto it. You do NOT weld frame at all. Big No-No. Only holes to be drilled would be in box floor for frame rails to bolt onto bed rails.
    Would this be the same for Pullrite super glide and Demco auto-glide?
    If so, I see why $500 would be an excessive price for the install.
    I haven't a clue as I'm not familiar w/ those brands.
  • mrad's avatar
    mrad
    Explorer II
  • If it previously had a rail type hitch, and the owner took them out, then just get a set of rails, or install a B&W turnover ball, and use several types of hitches.
  • There are holes in frame already and aftermarket rails made by B&W, Reese will bolt right onto it. You do NOT weld frame at all. Big No-No. Only holes to be drilled would be in box floor for frame rails to bolt onto bed rails.
  • I'm pretty sure you're not supposed to drill the frame (or was it weld). I would really research that before letting a shop do it "their own way".
  • mrad's avatar
    mrad
    Explorer II
    Michelle.S wrote:
    You don't list the year of your TV, but for my '11 3500 I purchased the rail mounting brackets from Reese that bolted directly to the Frame, only holes that were required were for the attachment of the Rails to the brackets.
    I would question someone that said they had their own way of mounting.
    sorry, 2013.
    Old Biscuit, I will have to go back and view the replies again. I recall one post telling me they thought $500 was a bit high. I do not recall mentioning in that post that the vehicle had already had a 5th wheel hitch on it. A friend of mine told me the other day that he had a pullrite and it had clamps that go around the frame. If that's all that is needed, and my truk has the box drill through for a fifth wheel hitch, I am trying to figure out why the frame would need to be drilled through.
  • You don't list the year of your TV, but for my '11 3500 I purchased the rail mounting brackets from Reese that bolted directly to the Frame, only holes that were required were for the attachment of the Rails to the brackets.
