imadtchmn wrote:
fj12ryder wrote:
You're probably out of luck trying to run E-rated 16" LT tires. That would only be a touch over 12,000 carrying capacity. Not enough overage IMO. You could go to G-rated LT tires if your rims will support 110 psi. Or change to 17.5" rims and tires. Or try your luck and stick with ST tires. Maxxis ST tires seem to be the trailer tire of choice.
After my ST tire failure I went with G-rated LT tires.
Now I am confused why you think he would be too close on tire weight. At 12,000, you would have approx. 3,200 on the tongue leaving 8,800 on the axles.
He said his axle weight was over 11,000 and pin on top of that.
