JohnG3
Mar 11, 2017Explorer II
Veebyes wrote:
Wow! The mistake was made the day the gelcoat was sprayed on the mold. Boats should be any colour as long as they are a shade of white. Dark colours on a boat exposed to the sun just do not last.
Weight is not so much a concern so boats tend to have thicker gelcoats than RVs.
An awful lot of labour & material went into restoring that boat. Maybe more than it is worth. RVs can be restored. 300 grit pads are extreme. Better to start with something like 3M rubbing compound. It is available in different grades depending on oxidation.
There is no such thing as one step to fix it. Start with the coarse compound & repeat using a finer compound to eventually multiple coats of a pure wax or sealant. Lots of work. Keeping it looking good will take waxing at least once a year.
If it is really that bad I'd look into having it sanded & painted with automotive paint followed by a couple coats of clear coat. That will have it looking better than new gelcoat.
Our Montana (white gel coat) had decals peel. Removing the bad decals left shadows where the gel coat wasn't faded. I Had very good results with Rejuvenater and a 7 inch buffer polishing out the exposed area. Hard to see where old decals were.
About Fifth Wheel Group
