jerem0621
Jan 03, 2015Explorer II
zackyboy3rs wrote:jerem0621 wrote:zackyboy3rs wrote:
Husky 16k was mentioned.
There are two Husky 16k Hitches. One is entry level slide bar design... One is arguably one of the best fifth wheel jaw design possible, the single jaw design. The slide bar is just that, a bar closes behind the kingpin and retains the kingpin very securely.
Here are the two different hitches
Husky 16k Slide Bar Hitch
Husky 16k Single Jaw Hitch
As far as safety.... the slide bar does a GREAT job.. the Single Jaw does as well. The biggest difference IMHO is that the single jaw hitch has a full floating head. The full floating head can make it easier to hitch and unhitch in uneven terrain.
Both hitches are good.
The slide bar Husky is the same thing as the Curt E16... You can see that in this link
Thanks!
Jeremiah
The hitch is the Husky 16k S. None pivioting head. I have to be EXACTLY lined up to get properly hooked and secure. Problem is when i am backing I can not see the hitch at all. 2nd concern (and a big one) is how do i deal with uneven sites? Do i need to take extra boards to raise truck tires? I have no clue.
Please any advice welcomed. Thanks.
Hi zackyboy3rs,
As far as dealing with an uneven site with a non pivoting head (I assume side to side pivot) yes, you will need boards to either lift one side or dig a hole on the other side to lower one side.
There is another hitch that you could look at that is getting some awesome reviews. It eliminates the problem of not being able to hitch up side to side and may let you be able to see the hitch through your back window.
The hitch is the Andersen Ultimate Fifth Wheel Connection...
Here is a Link to the hitch on Amazon.
Here is aVideo
Note you will use the rail version not the gooseneck version since you have rails already.
I don't have any experience with a non pivoting fiver hitch so my experience is based off of research only.
If the Andersen hitch doesn't tickle your fancy then another great alternative is the B&W Patriot hitch with the fully articulating head. Here is a Link
Now, what do we do about you not being able to see the hitch... Maybe some of the other experts here can help you with hitching when you can't see the fiver hitch.
Also, user ib516 uses a hitch like yours IIRC.. you may want to PM him for some tips on this hitch.
Thanks!
Jeremiah
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
