Charlie_D_
Jan 25, 2016Explorer
IAMICHABOD wrote:CA Traveler wrote:
The pole is similar to the Flagpole Buddy pole which has several problems:
1. The pins tend to wear larger holes in the pole.
2. The upper sections without pins tend to collapse.
Maybe they have a better pole - don't know. Where are they located?
Two other observations:
1. Their ladder mount requires climbing up the ladder. It is very short vertically which will place a lot more stress on the ladder.
2. Their $78 disk solar light is identical to the 2 I purchased on ebay for $20 each.
In my years of having and using a Poles and Holders pole in many harsh environment I have never had any of those problems. It is a better pole than the ones by Flagpole buddy,I have compared them when one failed at the beach one time in moderate winds.
The company is located in So Calif.
9970 Bell Ranch Drive, Unit 105
Santa Fe Springs, CA 90670
Never said they were cheap but sometimes you have to pay for a quality product.
I had problems with collapse but found if I twist hard as I extend it does not collapse. Have to hit the end firmly on the ground to collapse for storage. Ladder mount holder. Installed it at a lower level so I don;t have to climb and use a small bungee cord as high as I can reach to hold it against the ladder to keep it from banging around.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
