Old-Biscuit
Sep 27, 2016Explorer III
Texas Two Steppers wrote:
Thanks for the responses. When I say nose high I would have to lower the front of the rig 2-3 inches for the bubble to be in the middle of a level. By the highest position on spring hangers I mean the rig is highest at that setting. I am not sure maneuver Jack rig is, but the B&W hitch does not slide. I feel that I need the 7 inch clearance because we boondock camp a lot and need that much.
Where do you park rig....do you have to 'maneuver' (jack rig in)?
By that I mean....
Do you have to 'slide' 5th wheel into the parking spot where you have 5vr stored?
AS in 'jacking the truck and trailer at sharp angles when backing in/maneuvering to park it?
AS in causing trailer tires to slide---scuffing them---causing flat spots from tight maneuvering?
About Fifth Wheel Group
