laknox
Sep 27, 2016Nomad
Texas Two Steppers wrote:
Thanks for the responses. When I say nose high I would have to lower the front of the rig 2-3 inches for the bubble to be in the middle of a level. By the highest position on spring hangers I mean the rig is highest at that setting. I am not sure maneuver Jack rig is, but the B&W hitch does not slide. I feel that I need the 7 inch clearance because we boondock camp a lot and need that much.
Can we also assume that the springs are over the axles and not under? If so, you could add an easy 2" by installing a Correct Track system. It also gives you easy axle alignment. Any higher, then you're really looking at adding a sub-frame between the frame and the springs to lift the FW.
Lyle
About Fifth Wheel Group
