Firejpn
Aug 09, 2014Explorer
No prob give me a bit I'll put up pictures only bad thing is ya have to grind off some paint so for now mine has some white primer just to protect them a bit. I will need to at a threshold bridge to cover gap but after all this that will be no problem. The hardest part was moving the door out of the opening in order to cut and grind some of the spud that was left after the pin sheared. I did not undo spring actually used them to support the hinge side of the door. Just laid out to flat like deck and used pry bar to pry door out from under the hook at the bottom the stops over travel of door when down as ramp. This was easy as both pins where broken. *Side note if you have screen door on back roll it up before prying door out the second time we pried it out to do actual repair I only did it with 2 guys and door sprung up with springs and ripped the screen room door. I will repair with ethernabond tape for now should not cause problem just not pretty.
About Fifth Wheel Group
