LowRyter's avatar
LowRyter
Floor Rotten
I have a Weekend Warrior Super Lite 5th Wheel. The floor was rotted away at the entrance (side) door in area about 30 by 20 in.
It's a strange place since there is no plumbing there, although it's next to the refrigerator. The bottom has a vinyl insulation barrier but I believe it's rotted through. Perhaps the insulation gets wet there and holds moisture.
I've had the trailer for 10 years. I only use it about 3 or 4 weeks a year and turn the pump off when I am not using it. I winterize it as well and dump all the water. It's in covered storage when I am not using it.
For now I plan to screw a piece of plywood over it until I can get it fixed.
I am curious if anyone has experienced the same.
  • yes Cobra, it is some type of particle or strand board. You're saying that is delaminates on its own just by age?
  • I've seen some of these campers use particle board or blandex for the flooring.
    If so, that will be reason enough!
    Brian
