akcooper9's avatar
akcooper9
Folding Couch
Our TH has the couches that fold against the walls. Anyways we noticed the other day that the seats were sagging (not the brackets). Well the wife figured out why (see below).
Apparently this was the MFGs wise idea on how to support the foam. Any suggestions on a permanent replacement?
Moderators Edit: Adjusted photo width to 640 pixels per the forum guidelines. The Photo FAQ's has help & tips for posting photos.
  • Strabo wrote:
    Ours is the same, i use heavy zip ties in place of straps.....Plywood is worse, not comfy at all.
    Zip ties are a great idea. did you do the whole couch or just the broken ones?
  • Okay, now I see that is not a picture of the straps on the couch. Zip ties sound like a good plan. I will have to look at my couch and see how it is constructed.
  • Ours is the same, i use heavy zip ties in place of straps.....Plywood is worse, not comfy at all.
  • Heavy web straps or plywood between the frame and cushion. My TH is out camping right now with the wife and kids. I will check on how mine is constructed, I've only had my TH for about 2 weeks. A photo of the couch further away would be better view to get ideas.
