Kenc_AL
Jan 20, 2014Explorer
Jack_Diane_Freedom wrote:
I have a 2011 F-250 with the IBC. I set it at 9 and forget it. Towing 8000lb trailer. Remember these do not work like an aftermarket controller. They apply the brake proportionally very smoothly as you press the brake pedal and is integrated with the ABS of the truck. It does not 'grab' at all. Nice and smooth. It will only go to full 9 setting (or where ever you set it) only if you hammer the brakes and that is when you want the most braking.
X2 except 11,000 lb. Best controller I have ever had.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
