Traveler_II
Dec 08, 2013Explorer
tnclays wrote:
As butchfuzion said, you will have the 5 plastic covers in the bed; you can also look under the bed to see the under bed rails. If you have this set up, you need to order the Ford custom fifth wheel hitch from your dealer. I am liking mine so far, as it is easy to remove the hitch (in two pieces) from the bed when I need to haul stuff.
We have the package, but wanted to use our Trailer Saver air hitch. Trailer Saver makes a kit that works with the Ford set-up. So you don't need to use the Ford hitch. In our case we already had the air hitch and wanted to use it, but if you don't have a hitch getting the Ford total system probably would be a great idea.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
