merc1100sc's avatar
merc1100sc
Forest River Work and Play Questions
I think this is the right forum for this but not sure.
Anyhow,
I recently purchased a 2009 Work and Play 28. While brushing the snow off the roof today I noticed the roof appears to be a "floating" style roof. The aluminum seems to be just set on top of the trusses but secured on the sides of the trailer. On typical campers Ive looked at without aluminum roofs, the roof was tight to the trusses/surface. I just want to make sure this is how it's supposed to be.
Also, I have one vent cap that was so brittle, it cracked. Can I get on this roof to replace it? Again Ive walked on traditional camper roofs but mine seems constructed more similar to a motorcycle trailer. Just not sure of the roof's strength.
Thanks
  • It's normal for the aluminum roof on the W&P to float on the roof trusses. When it's hot it tends to float even higher in random spots. 1/4 - 1/2" is probably normal.
    If you walk on the roof got to be careful to place your feet directly over the trusses; otherwise, the aluminum sheeting will bend.
    Agree with Big Dog Bob, recommend standing/sitting on a small sheet of plywood while on the roof.
  • Hi I have a 2013 Work and Play also. I have been on my roof but had a 3 x 3 piece of plywood I was on . It helps distribute the weight..
