Reng8d
Sep 15, 2016Explorer
Frame Failure
Over the Labor Day weekend, we traveled to Colorado and when we arrived at our site and was setting up, my DW went to move the living area slide out and we heard this awful pop, I looked at how we wer...
Me Again wrote:WeBeFulltimers wrote:Reng8d wrote:mayo30 wrote:
Look at the axle and u bolts.Better prepare a reply for "severe jack knifing is the cause".How is the tire wear?The tire looks to be touching also or very close to it,probably hit you with overloading comments too.
I hear you...have to get to a real close 90 to get it parked on the pad at home, but definetly no jack knifing and most definelty no overloading, we keep to the bare essentials for weekend trips. I don't even carry any water in the holding tank, can't see carrying the extra weight...
Although "a real close 90" is technically not a "jack knife" it does put a severe twist on your axles the same as a jack knife. As a retired trucker of 20 years I have seen the damage that can be done even to commercial trailer suspensions if loaded and put under such stress. I avoid at all cost going over a 45 when backing mine. There is always another way of getting in that spot or find another more suitable spot.
Wetting the surface or a little sand thrown down will help the tires skid around.
