SMarquez's avatar
SMarquez
Freezer at 20, Reefer at 60
This a Dometic RM2652. I cleaned the burner, was't much there hardly any rust and nothing came out when I tapped on the flue. Lights up right away and stays lit. I get the same result from propane and 110v. It seems to me that it has been going this way just recently.I What am I missing here? It looks clean behind the access panel, nothing obvious bent, broken, burned or appears to leak. Looked at a bunch of youtube videos and didn't get much except a cooling unit replacement which might be out of my wheelhouse.
Thanks.
  • I use a small battery operated fan in the fresh food section. Has worked well since 1978.
  • There should be a white "clip" on one of the fins in the back of the fridge. That is the adjustment. Slide it up or down on the fin to adjust the amount of cold to each side of the box.
