mhardin wrote:
Why not just tell all of us?
Over a couple years I have found they place a made in America sticker inside on the bottom where the two lower doors join. Remove it and clean the glue. The center flap may or may not work, it has to close fully to maintain temp. If it still does not close you will need 2-4 nylon 3/16 washers from any hardware store,a 5/16 socket/nut driver and a flat screw driver. Next remove the trim on the top of the left lower door, you'll find 3 5/16 bolts, remove them. You can now remove that top hinge, the door should stay. Lift it up and off the lower hinge and set it aside. Clean the lower pivot and install the nylon washers as needed to raise the door. Reinstall the top hinge & check door alignment, make sure the flap is in place putting the door back on. Check door & flap operation. It should now close as it is supposed to.
Here's a YouTube on the fix:
www.youtube.com/watch?v=OMsPpc3DDx0
