I have a WW FB2100 with 2 50 gal fresh tanks. The front fresh tank is leaking where the drain exits the tank. I imagine I need to replace the fresh tank and don't know where to find a tank that's a ma...
That is not a fresh water tank, it is a waste tank. It should be the holding tank for the shower or kitchen. That is a waste dump valve dropping down from the Tee. Looks like something hit the drain line and tore the plumbing from the tank.
If your using this as a fresh water tank someone has screwed up your plumbing in a BAD way.
