Dick_B
Mar 07, 2016Explorer
I'm pretty sure the lower nuts just unscrew to allow the drain pipe to be removed then the upper nut unscrews BUT I'm not sure how the pipes connect to the tank bottom. Hopefully, the bottom could have a discharge pipe permanently attached to the tank.
I've had success plugging holes with JB Welds `Water Weld' which is an epoxy putty that is molded around the leak area and allowed to harden. Or Duluth Trading has an Extreme Tape sticks to itself and can be wrapped around to seal the leak.
About Fifth Wheel Group
