nayther
Mar 08, 2016Explorer
ThomasFour wrote:
Thanks Dick. I ordered the Duluth Trading extreme tape. Good stuff to have around anyway. Did some poking around today and pried back the broken collar a little bit. It is female threaded and plastic welded to the bottom of the tank. No easy way to replace it. I'm going with the Extreme tape as a hopefully more permanent fix....
yes the threaded piece is thermal welded to the tank then a slip/thread adapter is screwed into the first piece and everything else is PVC glued. In order to remove the slip/thread adapter you need to cut the pipe and unscrew it, then you can use a coupling and reglue or just replace it all, PVC is cheap and easy to work with. The drain valves are flanged so can be reused. If the fitting at the tank is the one leaking it was probably over tightened and cracked, not much you can do for that, special machine is needed to weld to the plastic.
About Fifth Wheel Group
