I need to go through the manual extensively this weekend. This camper has a very confusing valve and lever configuration. It has a gray tank pull lever, a black tank lever, a 2nd gray tank lever in the rear of the camper for the 2nd gray tank for the outside kitchen.
Then there's an unmarked pull lever that I "assume" is for the freshwater tank, but I'm not certain of that. And to top it all off, there are a couple of valves used to bypass the macerator pump.
Who knew the step up to a 5th wheel would be this complicated?
