bobbyg123's avatar
bobbyg123
Fresh water drain
So I’ve been going thru my new 5th wheel since taking delivery 2 weeks ago, and today I noticed some things about the tanks and valves that stumped me.
Unlike my previous 2 travel trailers, this Jayco Eagle doesn’t appear to have a simple fresh water drain. What I mean is that on my travel trailers, there was a simple screw cap valve on the underbelly that I’d twist off to train the fresh tank. With this unit, I have no idea how to train the tank. Is there a pull valve or something?
We’re taking our first trip this weekend, so I’ll finally have the chance to get familiar with everything, but the tanks are totally different than what I’m used to. There’s a fresh water, 2 gray tanks, a black tank, and macerator. That’s all fine and dandy, but how do I drain the fresh tank!!
  • My 2019 has a on-off valve to drain the fresh water tank on the exterior just under the edge of camper. My low point drain valves are behind a panel in basement compartment.
  • According to Jayco Manual
    3.Open the “fresh tank drain” valve. All fresh water tanks can be drained by one of two types of drain valves. A white plastic drain is attached to the exterior wall or a valve located inside the RV adjacent to the water tank (turn 45° to open or close).
    4.Open the “low point drains” by turning, then pulling the handles up. They are installed at the lowest point of the water lines. A label is placed on the outside of the RV to indicate where the drains are located.
    The drains will need to be operated from inside the RV.
    Once the label is found on the exterior sidewall, the drains will be found at a corresponding location in the interior
    Scavenger hunt!
    Good luck.
