BarryG20
May 05, 2018Explorer
Our trailer does not have gravity fill either. However it does have a "country fill" setting in the valve arrangement where it uses the onboard water pump to pump water into your tank. While it does work it is a real pain in the rear and I feel a ridiculous process to go through. At least on our trailer I have to clear out whatever I have in the storage area so that I can remove the bulkhead wall to get to the valve assemblies turn them the right way and then pump away then reverse the process to put it all back together.
Takes what should be a simple 5 minute job into significantly longer. To in essence save nothing in costs on the trailer but it did add to user aggravation though
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
