djousma
May 07, 2018Explorer
Me Again wrote:ACZL wrote:
Rob,
My '18 Big Country has vents for the fresh tank that come thru the frame rail. Once it's full it does seem like it "bleeds off" some, then stops. For the most part, our fresh tank gets filled 3x/year. 2x for sanitizing, 1x for w/e of dry camping. Never had a prob w/ venting, so I'll side w/ AP that the overflow tube is same as vent.
You you will have the same problem that most Landmark, BigHorn and other models have, in that you will loose a 1/3 to 1/2 of your water while traveling on the road. I put vinyl caps on the two vents while traveling. Chris
Same issue with my Cardinal. I installed a couple of quick shutoff valves to my tank drain, and overflow lines for use while travelling. Other than when travelling with a full tank, the overflows are always open.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
