Old-Biscuit
May 18, 2015Explorer III
YEP........inside the city water connection is a plunger/spring/o-ring assembly (check valve)
Remove screened washer and then with pressure relieved (open faucet cold side) you can try to reset by pushing in on tip of plunger....sometimes that works.
Sometimes the o-ring gets dislodged and then you have to remove city water connection from side of rig, disconnect plumbing line and then disassemble to fix.
I hate them cause they are cheap plastic junk.
I installed a garden hose 90* and then a garden hose shut-off valve.
They stay connected to connection on side of my 5vr (same set up on black tank flush)
Valve closed....when using pump
Valve open when using hose
DONE!
You can also just screw in a 3/4" PVC plug when using pump
DONE!
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
