Wrong_Lane
May 19, 2015Explorer
The screw in plug to block water from exiting the fitting is available at any store that sells RV supplies, Walmart has them for about $1.00. They even come with a lanyard to attach to your RV so the plug will not get lost.
The replacement valve is under $20.00. You need to look at the way your current one is connected as the replacement valves are available for connecting to both male and female fittings. You need to know which you need.
It's an easy fix.
It's an easy fix.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
