AZ_T_T
May 26, 2013Explorer
This is a common problem with Jayco's. My FW has 2 long flat fresh water tanks and each tank has an over flow hose. It is easy for water spill out and in some cases create a siphon . I ended up tying the two over flow hoses together and then added a spigot at the end . When filling the tanks the spigot is open and when I'm driving it is closed.
I would actually loose 2/3's of my fresh water on a 3 hour drive.
Good luck.
Good luck.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
